draftbit integration Possibility with Pabbly Connect
Status: Closed · Asked by Saurabh Arora on · 0 views
Souravarora — Question ·
Hi Team , i am using draftbit services. Can pabbly connect be integrated like zappier. Please share solution. Regards
Hey @Souravarora
Kindly create a submission on the HelloNext- https://pabbly.hellonext.co/ and upvote it so our technical team can create endpoints for you.
Please make sure that whatever updates with features you are required to update in the HelloNext so that our team will build those endpoints with the features needed for you.
Souravarora — Reply ·
Unable to find draftbit
Currently, Draftbit's integration is not available on the platform but you may post the submission to the platform here - https://pabbly.hellonext.co/
