Driving Routes, Location distance
Status: Closed · Asked by wibbler on · 0 views
wibbler — Question ·
Does anyone know of a way Pabbly could help with the following two scenarios:
- Automate the best driving route for a a set of Zip codes (like speedyroute.com or Google Maps)
- Work out the driving distance between two locations (like Google Maps)
Hey @wibbler
We looked into your use case and seems like it is not possible for now.
wibbler — Reply ·
Hey - just revisiting this question a year later - does anyone know of a way to get driving distance between two points into Pabbly?
At the moment I have a workaround: Pabbly enters the two points into Google Sheets, uses the googlemaps_distance module to calculate, and then Pabbly gets the resulting information. However, it only works 50% of the time, as formula refresh on Google Sheets is intermittent unless you are looking at the sheet.
I am afraid we couldn't find a workaround for this.
