Dropbox and Iterator by Pabbly, Date/Time Formatter by Pabbly
Status: Open · Asked by sjl on · 0 views
x
Hey @sjl
I'm encountering difficulties when trying to replicate this process with Pabbly, specifically with the Iterator function. It seems I cannot select any array using Iterator. Could you advise me on what I might be doing incorrectly?
Kindly refer to the following video lesson on how you can use the Iterator action step since you need to capture the API response in advance response by toggling the "Simple Response" button.
youtube.com/watch?v=zJaGQ-SIB0I
Is it feasible to map the variable in Pabbly as I could do in another tool? I've observed that Pabbly lists all files, but my aim is to search for a file with a specific date format (YYYY-MM-DD). Ideally, I'd like to select only the file name variable and search files containing this date format. Is this possible?
Additionally, could you kindly provide the URL of the workflow where you attempted this? Furthermore, I recommend watching the following video, which can provide you with insights into using the "contains" Filter type:
Hello ArshilAhmad,
Thanks for the concern, but I've decided to dance with a different automation partner for this task let's see if I can pull a simple task with Pebbly now. But hey, it's the thought that counts, right?
Cheers
