Dropdown - Insert from Previous Steps is NOT Showing Up
Status: Closed · Asked by realestatebroker on · 0 views
realestatebroker — Question ·
Fagun Shah — Reply ·
Dropdown - Insert from Previous Steps is NOT Showing Up -
Workflow: https://connect.pabbly.com/workflow/share/C0MAMgBXA2ACSAJoBVYNKgAUUVUIUQlsABlTQQEOB39aAAZtBkdbMQpGWXtVElQ1BUwEbgVZBzwLHwsPVwEGdVdaVXlWVQd9AE0GfVMaDzwLVQAoAGE#
Step 7: OpenAI Dall-E Create Image
None of the previous steps in the route are showing, only the steps BEFORE the router.
Same issue is happening with me.
Fagun Shah
- Automation Freelancer
realestatebroker — Reply ·
yes it just started this morning .. something on pabbly side
Agree, I setup the similar type of workflow 2-days ago without any issues. But from today morning it is giving issues.
@Supreme check this.
Fagun Shah
I think it is working again. I just completed the setup of my workflow.
Fagun Shah
Pabbly13 — Reply ·
Hey @Fagun Shah & @realestatebroker !
The Router concern is fixed.
You will be able to see previous steps of routes now.
Kindly check at your end now.
Jiten — Reply ·
Hi, I am facing the same issue. Please can someone help?
Pabbly13 — Reply ·
Hey @Jiten !
Can you provide us with a small video recording, so accordingly we can guide you further on it.
Hope, to hear from you soon.
