Duitku Payment Integration Problem
Status: Closed · Asked by JEREMY TANUARDY on · 0 views
jer3 — Question ·
Recently im using Duitku as integrated payment
And in Pabbly setting, recently I must put custom code for the payment method
In Duitku, they have a lot of payment methods, such as
I want to give 3 choices to my user
So i have setting 3 times and make sure rename them to help my customer choose payment method
Then problem came when customer go to checkout page, they found out my payment option is such look like a riddle game
How to fix this?
- it really tired to add one by one payment option, can i put several payment code instead in the integration so let the payment option go to the duitku page?
I've contacted duitku and they confirmed from their side, i can only do 1 payment method per integration
- If that not possible for now, can i do custom to the logo and name? So i can put the right images and name for the payment method i use
Hope this information help
Thank you
Sonam — Reply ·
How to fix this?
Thank you
Hi Jeremy,
We have fixed the issue for you. The gateway name is now reflecting properly on the checkout page -
Hope this helps.
jer3 — Reply ·
Hi Jeremy,
Hope this helps.
Hi, thank you for update, it really helpful for now. But, can use custom logo for each payment processor? Since they have a lot of payment processor, better if they have different icon based on payment method
Sonam — Reply ·
Such a case won't be possible from our side as it is reflecting directly from the payment gateway.
jer3 — Reply ·
Ok got it, it is ok for now i solved the problem. Thanks for help!
jer3 — Reply ·
is there any update from ipaymu?
Adrimx — Reply ·
Hi Jeremy,
Could you help me to install duitku payment? I would be happy if you could. Thank you.
Regards
