Duplicate Entries while Using Zoho CRM with Airtable connection - Create Record
Status: Closed · Asked by Nayan Verma on · 0 views
When i am using Zoho CRM with airtable whenever a record create in the module duplicate entries are done in Airtable.
Kindly help me resolve this
Hey @nayan123
Can you please share the workflow URL once in which you have tried the same? So that we can look into it.
Below is the workflow URL
https://connect.pabbly.com/workflow/share/C0NXZVUCCGtVH1I4BVZWcQAUAQUHXghpABkBE11SB38ESQBVVxYPZQtHVHZXAFMyAksAalINDGkNGVFVAlRWJQcKUn5VVlMpAUwJOgdCDD8LVVd_VTQ#
Currently the situation is looks ok if opted for a different connection of the same application but when i use other connection it was giving me duplicate entries
It appears that you might have pressed the "Save & Send Test Request" on the trigger event, which has created multiple webhooks in your Zoho CRM account and because of that, the trigger event is passing the duplicate entry multiple times.
