Duplicate Execution of the Flow
Status: Closed · Asked by manmeetsinghbhatti on · 0 views
Hi , I have created Flow to automate the customer created in Hubspot to another CRM My Pipeline . Whenever a new contact is created in Hubspot a new contact is also created in MyPipeline , However this flow keeps on repeating every 15 minutes resulting in consumption my permitted tasks. I have to manually close the flow from triggering . Please help me to resolve,
Hey @manmeetsinghbhatti
Could you please use the latest trigger event New Contact Added in the hubspot and then run the workflow?
Ok I will check and update
Hi @Kunal Valuskar ,
I have now created the flow once again . Today is 26th October , The Trigger of 15th is getting triggered again and again resulting in the usage of my tasks . Snapshot attached. New contacts haev been added in the hubspot today , ut they are not getting triggered. Any solution for this. Rgds, Manmeet
Could you please check the task history for the workflow Hubspot2Mypipeline? We can check that you have got the latest lead in the Hubspot on 27th October successfully and it has created a contact in My Pipeline as well. Screenshot for your refernece:-
Kunal
