Duplicate subscription issue In create customer with subscription
Hello Team,
I am using pabbly subscription billing APIs but when i am using create customer with subscription and sometime when its hits multiple times , THE ISSUE FOUND DUPLICATE SUBSCRIPTIONS CREATING WITH SAME CUSTOMER.
Regards,
Hello @chirag-yopmail,
AD_4nXdhUKey9--1ZdBRxy3UK5P5fDJKizdxrQDoL8zlve4yt3YDpDREwIp1qPAxtgqRMWDxjtdOIt8phHaEwxppC5qiyDyp1S_EATVhFG8E8floJo6Esv6ih3tBAUUcZQjdUDvBlAu_ew
Thank you for the clarification. This behavior should not occur. If the same endpoint is hit with identical details, a new contact should not be created since we perform a check by email. If the email already exists, the customer record is not duplicated.
However, to investigate further, could you please share a screen recording of the process where hitting the endpoint twice is creating duplicate contacts with the same email? Additionally, kindly provide the email address associated with the PSB account where these contacts were created.
Hey @Preeti Paryani ,
Thanks for the reply , unfortunately i am not able to share the screen recording but i am sharing screenshots of the api that i am using and the result i am getting in PSB.
kindly check and let me know.
Thank you for sharing the screenshots. From what we see, you are using the Create Custom with Subscription endpoint, which is resulting in multiple subscriptions being created under the same email address.
To verify whether a new customer is also being created for every subscription, we would require the email ID linked with your Family Subscription Billing account. You can find this by logging into your account, clicking on your profile, and copying the email displayed there. Please share this with us so we can check it under your account.
Based on our current investigation, the screenshots you’ve shared are from the Subscription section, where the same email is correctly linked with three different subscriptions.
