Dynamic Connection Selection and Automated Workflow Execution Using Platform API
Status: Awaiting reply · Asked by Anshuman Nag on · 0 views
Hi Pabbly Team,
I have been experimenting with the new Pabbly Connect Platform API and have successfully tested the following:
Generating OAuth authorization links programmatically.
Authorizing different Google accounts using the generated links.
Retrieving connection IDs and checking connection status.
Retrieving OAuth access tokens through the Platform API.
Using API-generated connections within regular Pabbly workflows.
Executing Google Business Profile API requests through Custom API Request (Beta).
I have a few technical questions regarding the integration architecture:
1. Dynamic connection selection
Is it possible to dynamically select an existing app connection within a workflow by passing its connection ID through an incoming webhook?
For example, can a single workflow execute Google Business Profile operations using different authorized Google connections depending on the incoming request?
2. Automated workflow provisioning
If dynamic connection selection is not supported, is there a way to programmatically:
Create or clone an existing workflow.
Assign an existing connection ID to an action.
Configure action parameters.
Enable or disable the workflow.
Retrieve its webhook URL.
Can these operations be performed using the REST API, SDK or Workflow Builder MCP without manual intervention?
3. Direct API execution
Can OAuth access tokens retrieved through the Platform API be used directly by an external application's backend to execute Google Business Profile API requests?
Are there any Google Business Profile-specific restrictions or limitations associated with this approach?
4. OAuth completion and redirection
Does the Platform API support custom redirect URLs or completion callbacks after successful OAuth authorization?
Can the requesting application's name be displayed on the authorization invitation page?
5. Recommended architecture
What is the officially recommended architecture for executing application-specific actions programmatically across multiple independently authorized connections, without manually configuring workflows for every connection?
If possible, please share relevant API endpoints, documentation or implementation examples.
Thank you!
