Easy CSV missing base function
Status: Closed · Asked by James Buchanan on · 0 views
Integromat and Zapier can both create CSV files using easycsv
https://www.easycsv.io/docs/generate-csv-files#post_request
But In Pabbly the only option is import as shown in the screenshot below, can we please get a post to create csv request?
Hey @James B
For your concern, we would recommend you to use the "API by Pabbly " action step where you can configure the desired action step in your workflow with the help of the API documentation of the application.
You can also refer to the following video tutorial for your better understanding.
