Edit milestones within a project
Status: Closed · Asked by Hermes on · 0 views
I want to edit a milestone within a project, like this
To do this I have this action:
Custom API request POST
Full url: https://hera.flowlu.com/api/v1/module/st/stage_checkitems/update/27
JSON: {"report" : "BTW bedraagt 674 Fiscus 2021-07-13" , "description" : "BTW bedraagt 674 Fiscus 2021-07-13", "active":1 }
Somehow it doesnt work. Can you help me with what fields needs to be changed to complete a milestone and edit the report
I see: "active" and "checked" should be true or false, but that doesnt change
We are looking into and will update you.
Hey @Hermes
We looked over your API and tried the same at our end too. But it is not working accordingly and neither it is updating. So, we would recommend you to contact Flowlu's support for better understanding.
