Edit: Problem was temporary and now I can't find how to delete this post? (Is there a limitation to the number of fields that can be synched?)
Status: Closed · Asked by Lars on · 0 views
Lars — Question ·
I just created a workflow to sync data from a Google Sheet to Mailerlite Classic. For some reason one of the fields at the very end of the list is not being synched, despite the trigger column being the very last column. What might be causing this?
Hi @Lars,
Could you please confirm whether the issue is fixed?
Lars — Reply ·
Hi, yes i tested inserting a new column and for some reason that helped.
Where do I go to delete this post?
Thank you for the update. I have closed this thread on your behalf.
