Emails still send after cancel/reschedule in same workflow
Status: Open · Asked by Bobby on · 0 views
Bobby — Question ·
Task History ID: IjU3NjUwNTZhMDYzMzA0MzA1MjZhNTUzMzUxM2I1MTY3NTQzMjBmMzYi_pc
Hi Pabbly Support Team,
I’m having an issue with a Pabbly Connect workflow where reminder emails still get sent even if a Google Calendar event was canceled or rescheduled. I Think i need to modify my workflow. Can you guide me on how I can do that how i can check Google Calendar status and i also want to send a emails reminder to customers for meeting
Hi @kumarbobbyldh,
Currently, you are mapping the meeting status from step 13 of your workflow, which will give you the older event status. Instead, you should add a 'Get Event by ID' action step after each Delay step to retrieve the current status of the event. Then, use this updated status in the Filter step.
Arshil Ahmad
?Rate your support
Bobby — Reply ·
I have one problem, im not using the same form for canceled or rescheduled how its work then
Bobby — Reply ·
I have two workflows, one is to send a reminder email and one is to canceled or rescheduled booking
Bobby — Reply ·
If possible, can we meet, and I will explain to you better
Bobby — Reply ·
