Empty cells not syncing
Lars
I just discovered that when syncing data between Google sheets, a cell where a value has been deleted does not get synced, so the old value remains in the target sheet. Process:
  1. User updates data via google form
  2. Update triggers workflow to update target sheet with corresponding values
  3. Updated values get synced as expected
And here’s where the problem appears – if the user deletes a value in their form, that value doesn’t get synced to the target sheet.
Anyone encountered this and has a solution?
Thanks,
Lars.
Hey @Lars
Can you please share the name of the workflow, which you have tried?
