Encharge Integration for Subaccount
Status: Closed · Asked by KatOak on · 0 views
I am trying to connect my Encharge subaccount with Pabbly as a new encharge integration - but I am not getting the option to add the API key - it just keeps asking me to log into my Encharge accoutn to connect - but that is simply connecting me to my main account again.
How do I crate a connection for my sub account?
Hi @KatOak,
Pabbly’s native Encharge integration is OAuth-based, not API-key-based. That’s why it keeps redirecting you to login instead of asking for an API key.
If you are able to log in to your Encharge sub-account separately, then log in to your Encharge sub-account and Pabbly Connect account in an incognito tab, and then attempt to create a new connection. It should connect to your sub-account instead of the main account.
Arshil Ahmad
Hi @KatOak,Pabbly’s native Encharge integration is OAuth-based, not API-key-based. That’s why it keeps redirecting you to login instead of asking for an API key.
Arshil Ahmad
I will give the incognito tab a go because right now whether I am logged in or not when I try to connect it always asks me to relog in which means the main account not the sub account :(
Sure, do let us know how it goes when you attempt to create a new connection in an incognito tab.
Arshil Ahmad
Sure, do let us know how it goes when you attempt to create a new connection in an incognito tab.Thanks & Regards,
Arshil Ahmad
That worked thank you so much - I assuem that now I have the second connection set up I don't need to be in incognito to use it just selct it from the drop down.
Thank you for your help
Could you please share a screenshot of the dropdown you are referring to? Also, please share the workflow URL where you have set up the connection with your subaccount.
Arshil Ahmad
