Error in custom entities requests for Flexie.io
Status: Closed · Asked by Hermes on · 0 views
When I want to create a custom entity I get invalid api, while I want to get details of the account it's okay.
Can you share the workflow name once so that we can review it once?
Tasks created in Flowlu https://connect.pabbly.com/workflow/mapping/Ijc0NDc1Ig_3D_3D
Can you confirm if you have the table already created in your Flexie.io account? It will appear something like this -
Else, please create a custom entity table schema first in your Flexie.io account, and then you can use create custom entity in Pabbly Connect workflow to create new records in your custom entity table -
I have many custom entities, but they are not loaded because I get an api error, while on accounts level I dont get an error. Only at custom entities level.
Thanks for the details and screenshot. We will check and get back to you.
Please reauthorize create custom entity step again. It should work properly now.
Perfect, thanks
