Error in custom entities requests for Flexie.io
Status: Closed · Asked by Hermes on · 0 views
Hermes — Question ·
When I want to create a custom entity I get invalid api, while I want to get details of the account it's okay.
Best regards,
[EMAIL='[email hidden]']Hermes[/EMAIL]
Connect with me on LinkedIn
Pabbly — Reply ·
Can you share the workflow name once so that we can review it once?
Pabbly — Reply ·
Can you confirm if you have the table already created in your Flexie.io account? It will appear something like this -
Else, please create a custom entity table schema first in your Flexie.io account, and then you can use create custom entity in Pabbly Connect workflow to create new records in your custom entity table -
Hermes — Reply ·
I have many custom entities, but they are not loaded because I get an api error, while on accounts level I dont get an error. Only at custom entities level.
Best regards,
Pabbly — Reply ·
Thanks for the details and screenshot. We will check and get back to you.
Pabbly — Reply ·
Please reauthorize create custom entity step again. It should work properly now.
