Error in fields to generate subscription order in Click Funnel and Create subscription in woocomerce using webhooks
Status: Open · Asked by thewebsell.email.test@gma on · 0 views
thewebsell.email.test@gma — Question ·
Task History ID: IjU3NmQwNTZiMDYzMDA0MzU1MjY0NTUzYyI_3D_pc
Estoy generando una orden de suscripción en click funels pero cuando la envío a woocomerce me genera errores en algunos campos, ¿cómo puedo corregir esto o verificar que campo debo seleccionar para que funcione correctamente?
screencapture-connect-pabbly-workflow-mapping-IjU3NmQwNTZiMDYzMDA0MzU1MjY0NTUzYyI-3D-pc-2023-0...png
Hey @thewebsell.email.test@gma,
thewebsell.email.test@gma — Reply ·
Already added as a member, I look forward to hearing from you.
Can you please pass the Customer Id in the Customer field with the help of the "WooCommerce: Retrieve a Customer by Email" action step? As we can see you are passing the random number from the trigger response.
How can I identify which field the customer ID is associated to, so that it is a valid field for woocomerce?
As mentioned in the previous message you can use the "WooCommerce: Retrieve a Customer by Email" to get the customer Id that is associated with this subscription and update it.
[IMG width="571px" alt="2023-05-08_16h52_48.png"]https://forum.pabbly.com/attachments/2023-05-08_16h52_48-png.25717/[/IMG]
[IMG width="585px" alt="1683546746299.png"]https://forum.pabbly.com/attachments/1683546746299-png.25714/[/IMG]
