Error, using Pabbly + HubSpot
Status: Closed · Asked by snakeeyes on · 0 views
snakeeyes — Question ·
Hey, hope you are well. I am going to save some orders. When I create new contact in HubSpot CRM. They are saved with no any problem. But when I am going to saved as Update Contact in HubSpot CRM, I select every field. But when I hit the saved button the view go back and did not save change or the landing page loading for long time then session will be expire Why????
Hey @snakeeyes
Our integration team is currently looking into it, kindly allow us some time.
snakeeyes — Reply ·
Hey @snakeeyes
issue again
Hey @snakeeyes
We are still working on it and might take some more time. I hope you would understand.
Regards
Hey @snakeeyes
We have made some changes in Hubspot's Create Contact (with All Properties) action event, kindly now try the action event by re-connecting it and let us know how it works for you.
Hey @snakeeyes
Could you please tell us that have you tried Hubspot's Create Contact (with All Properties) action event at your end yet? If yes then kindly let us know how it works for you.
