Facebook Conversion API tracking problem
Status: Closed · Asked by dtt on · 0 views
Hi there,
I'm trying to track a Facebook Conversion, but I'm getting an error:
(#100) param data must be an array.
as you can see attached.
Where am I doing wrong?
Thanks in advance.
Hey @dtt
Could you please share your cornering workflow with us, so that we can look into it and can assist you accordingly? Meanwhile, you can try once by passing the "Content Id" in double-quotes as mentioned in the help text beneath the field, since you haven't passed it in double-quotes.
Kindly try this at your end and let us know if that works for you.
Regards
You're a real Supreme! Your solution solved my issue. Thanks, have a wonderful day!
