Facebook post to Linkedin automation
Status: Closed · Asked by Guy Dinay on · 0 views
I need to create a Facebook post for Linkedin automation.
This is the post:
https://www.facebook.com/gorillabotchat/posts/pfbid027aVH4rVEzoJ6nDm85NfwhymxZ4XuJJLt4ocAavpXoFxJ6EDwuRuAC3B9TDXBdUzql
The URL for the article is in the body of the text.
What do I need to use to generate the image of the post to the LinkedIn post?
I tried this one but I'm not sure if this is the right one and what should I add to the article URL.
https://connect.pabbly.com/workflow/mapping/IjU3NmQwNTZkMDYzMzA0M2Q1MjZiNTUzNCI_3D_pc
Hey @guyseo
Can you please tell us that you want to set the URL thumbnail for the content?
I upload manually the image to the post.
you can see how it is here:
Whats the best way to do it so it will take the image to the LinkedIn?
Hey @guyseo
Kindly try the following action step once and let us know if that works for you.
But what is the article URL that you added?
the image path?
The article URL is in the body text
Yes, you can try passing the image URL in the Article URL field of the action step.
