Facing issues in Connecting Mailercloud and Pabbly
Status: Closed · Asked by RedTeam Automation on · 0 views
I attempted to apply in Pabbly Connect after creating an API key in Mailerclould. It indicates that the API key is invalid. I have no idea why it is showing. Is this because the Pabby connect is from a different email address, and the mailercloud is associated with a different Gmail account? Please assist me in finding a quick solution to this.
Hello @RedTeamAutomation,
Could you please try generating a new API key and setting up the connection again If the issue persists, kindly provide a short screen recording to help us better understand the problem.
You can also refer to this tutorial for guidance on setting up the MailerCloud connection: MailerCloud Setup Tutorial.
I appreciate your support. The problem is resolved. The matter concerned the deactivation of the account. Thank you @Preeti Paryani
Hello @RedTeam Automation
Thanks for the update!
