Facing problem to link public slack channel in pabbly
Status: Open · Asked by Nbfcadvisory on · 0 views
nbfcadvisory — Question ·
Hi @nbfcadvisory,
Could you please record a short screen recording showing the issue you encounter while making a new connection with your Slack account?
Arshita — Reply ·
Upon checking, it appears that you have successfully created a new connection with the "Slack" application, and it is functioning properly. Now, the name of the channel is listed in the dropdown menu.
