Fail to extract correct phone number
Status: Closed · Asked by Raviolpub on · 0 views
Raviolpub — Question ·
Hi, i have a problem. I need to extract a phone number from a body mail, but the formatter cut me the phone number, it cut last 1 o 2 number. How i can fix it?
Fagun Shah — Reply ·
If you are only getting one phone number , then try this solution instead,
Fagun Shah
- Automation Freelancer
