features on Messagebird
Status: Closed · Asked by Assistenza S1 Trail on · 0 views
Hello is there a way to send a whatsapp message using messagebird templates?
regards
With the current Messagebird integration, you can "Send SMS" and "Send Voice Messages" - https://www.pabbly.com/connect/integrations/messagebird/
Yes, but not whatsapp. So the answer is no. Thanks
You can request for more trigger or actions here - https://pabbly.hellonext.co/b/Update-Existing-Application
The integration team shall look into and can add them after checking the compatibility.
Thanks!
