Few Issues in Using Chatflow
taxajca
1) Whenever a chat is assigned to some team member, next time when client texts after even 2/3 mins then it gets assigned to another one. I want that chat to be assigned to same person whom it was assigned earlier. In our case dedicated RM/case experts are for clients so once a chat is assigned to someone it should be with him all the time untill manually assigned to someone else.
2) We aren't able to send message to anyone directly from our end, even through templates and even after client has interacted with us.
3) Automated/Triggered Messages aren't being sent to clients whom we have been interacting over Pabbly Chatflow
4) Chat Flows doesnt triggers all the time even after setting up keywords and regen.
5) Chats should be highlighted which hasn't been reverted by anyone.
Hello @taxajca,
We have tested this issue with our account; however can't replicate the issue. We are monitoring the chat behavior under your account.
Could you please share some chat examples showing the same?
Could you please elaborate more about this? Are the messages automated under flows or workflows?
No such feature is currently available. If once opened, it would be highlighted further if not reverted.
taxajca
Hi @Preeti Paryani yesterday i had a call with @Soumya Tripathi on which we discussed some of this queries out of which
1) May be due to Round Robin Rule, which i have deactivated so shouldnt be the issue now, shall keep you posted
2&3) Attached Screenshots - 1 with existing client with whom we have been chatting regularly 2- New Lead to whom first time message was being sent through Trigger from Zoho CRM. Both were not being sent, this is a serious concern for us since the sole purpose is automation
4) Resolved
5) Understood
Hrishabh.pabbly
Hello @taxajca,
Thank you for sharing the screenshot.
The issue you're facing is due to a restriction from Meta’s end. The error code 131049 generally indicates that Meta has temporarily blocked message delivery to prevent spam or policy violations.
This can happen if:
  • Too many messages were sent in a short period
  • The message template is being used in a way that violates Meta’s guidelines
  • The recipient has not interacted recently (outside the 24-hour window)
We recommend waiting for some time and then trying again. If the issue persists, consider using a different approved template or reviewing your message flow.
Let us know if you need further help.
taxajca
Hi @Preeti Paryani & @Resham i really need help in chat assignment thing, since we deal with more than 500 clients/chats on daily basis with dedicated and mostly fixed relationship manager/agent. Any trigger flow or automated messages moves the chats to unassigned and makes hard to follow up and track
can you guys help in this please? I just dont want chats assigned team member to change automatically in any case, it has to be manual, no matter what.
Hello @taxajca,
As discussed during our call, please share the phone number where you observed this behavior so we can investigate the issue accordingly.
taxajca
here it is
Sanjay Sannapa: 8505959079
Panjak Chhabra: 9041623226
Neha : 9960877313
Veena Bairagi: 7000892898
Thanks for sharing the details.
We’ll look into the issue tomorrow and first test it using our own account. After reviewing, we’ll discuss it internally with our team. If we feel a meeting is necessary, we’ll inform you accordingly. We appreciate your patience and understanding.
Hello @taxajca,
We’ve been monitoring the issue, but to check this in real-time, would you be available to join us for a Google Meet?
We’re available during the following slots today:
12:00–1:00 PM or 4:00–5:00 PM
Please let us know your preferred time, and we’ll send over the meeting link accordingly.
Hello @taxajca,
As discussed over the call, the requested slot is currently unavailable. However, I will be sharing an alternate available slot with you shortly and will inform you over a call once it's finalized.
