Field Mapping - Double Connection
theliduk
Not sure if the title is correct also! I always come with different problems—apologies about it.
I have TicketTailor flow to Sertifier now. In TicketTailor, there are over 100 events happening listed. Unfortunately, in their API order.created the venue of the event is not sent to Pabbly. Other fields are perfectly coming into pabbly. I contacted the TicketTailor API team, and they said that adding Venue in this API is in their pipeline.
Now, I wanted to add the venue to the certificates. How can I do it? My wild thought is to create a Google Sheet with the exact event name and its corresponding venue. Or if am using the router I need to perform a condition check to run it and include the venue in the certificate like match-making. If am going to use router, I need to use 100 conditions for 100 events. Although it is free of cost, it consumes a lot of time.
Any alternative solutions?
Supreme
Hey @theliduk
No, there is no other possibility to use the router action step. To achieve your filter condition individually you need to use the number of routes.
Further, if you want to get the venue via action then refer to the following screenshot.
Supreme
Hey @theliduk
