Field match issue! Educate me please
Status: Closed · Asked by EricHowell on · 0 views
I just did another Word document and it still is not matching the fields.
Hey @EricHowell
We can see that in Data In we are correctly sending the data in the fields. However we are not sure about the Data Out field as it is not giving any information.
Meanwhile could you please remove the extra spaces in the {{ contact.seller_1_name}} and then try to pass the values in the document and let me know if it helps.
Kunal
Kunal, yes I figured it out yesterday. That is the issue. The Spaces. Thank you
Kunal I was wrong. I am still having the same issue. https://www.loom.com/share/5e68bca14ca24f889c9106b07a9e4954
Hey @EricHowellWe can see that in Data In we are correctly sending the data in the fields. However we are not sure about the Data Out field as it is not giving any information.
Kunal
Kunal
Here is one of the workflows https://connect.pabbly.com/workflow/share/D0cFNwVSBGdVH1c6URoHIFxIAwcGXwlpVE0EFlVaBn5WDFQBUxIIYlsXAyEFUlMyXxYCaANfADwBFVZSVQMBcgMNARQEGwdaVmUARVYJASsPbQ##
I thought that I could close the brackets and it would work. But after doing it, I am still having the same issue.
@Supreme or @Kunal
I would greatly appreciate help on this matter.
Thank you in advance
Hey @EricHowell
I would like to request you to manually input the text instead of simply copying and pasting it into the document. Once you have manually input the text, please reconnect and try to pass the values in the document as needed.
If you experience any issues or errors while passing the values, please let me know and I will be happy to assist you further.
Manually typing the text worked. Thank you.
