Field(s) location_slug character length exceeded the allowed max value. - SOLVED
Status: Closed · Asked by alicat876 on · 0 views
alicat876 — Question ·
Task History ID - IjU3NjUwNTZjMDYzZjA0MzU1MjY1NTUzZDUxMzU1MTYyNTQzODBmMzIi_pc
Even with Location Slug empty, I get this error and I have no clue how to fix it. The old connection worked perfectly and now...
The integration is More Good Reviews.
alicat876 — Reply ·
Solved on the More Good Reviews end,
Hello @alicat876,
Thanks for the update.
