Filter does not work. Help please
Status: Closed · Asked by Illia.Kovalov@bakotech.com on · 0 views
ilyakovalov — Question ·
Hi.
I'm trying to connect Weblium with SendPulse.
When I use 2step automation (Weblium + SendPulse) - it works. Pabbly creates new subscriber to SendPulse.
But when I trying to use filter (Weblium + Filter + SendPulse) - it does not work correctly.
I've checked parameters (many times) - the filter shows me success for my rule - https://prnt.sc/hqSYI26bZxHQ
But when I send the form with data, which is equal my filter - the task is not completed. And subscriber is not sent to SendPulse.
I think it's a bug. Can you help me?
Hey @ilyakovalov
As we can see from your workflow, the field which you have used in the filter action step doesn't appear in your " Weblium: New Form Submission" trigger response and because of that your Filter action step didn't let the data move.
Kindly make sure that the field which you have used must contain the respective data and the same field should also be appearing in the trigger response.
