ilyakovalov
Hi.
I'm trying to connect Weblium with SendPulse.
When I use 2step automation (Weblium + SendPulse) - it works. Pabbly creates new subscriber to SendPulse.
But when I trying to use filter (Weblium + Filter + SendPulse) - it does not work correctly.
I've checked parameters (many times) - the filter shows me success for my rule - https://prnt.sc/hqSYI26bZxHQ
But when I send the form with data, which is equal my filter - the task is not completed. And subscriber is not sent to SendPulse.
I think it's a bug. Can you help me?
