Filter help
Status: Closed · Asked by Christina Winter on · 0 views
Christina Winter — Question ·
I am having a hard time setting uo and using the filter in my new workflow. https://connect.pabbly.com/v2/app/workflow/mapping/IjU3NjcwNTY5MDYzMDA0Mzc1MjZiNTUzZDUxMzci_pc
I want to filter webinar date choices in the sign up form.
I have tried the full date "Tuesday July 21" I have tried July 21, and also 21st but each time it moves on to the next step and triggers another workflow for Tuesday July 14  (this old workflow https://connect.pabbly.com/v2/app/workflow/mapping/IjU3NjcwNTY5MDYzNTA0MzE1MjZkNTUzMjUxMzQi_pc)
How can I fix this so the subscriber is filtered correctly?
Thank you so much
Work — Reply ·
Hey Can we also connect Facebook page on pabbly
Pabbly Support — Reply ·
Hello Christina,
Your workflow is configured to trigger on every Kajabi form submission. It contains two routes: one for July 21 and another for July 23.
  • The July 21 route is configured to execute when the field payload 0 attributes custom_3 contains "July 21st".
  • The July 23 route is configured to execute when the field payload 0 attributes custom_3 contains "23rd".
Now, the reason Route 2 is executing in your other workflow is that you have configured it to execute when the field contains "Tuesday, July 14".
Please change the condition to "July 14" or simply "14" instead. This should resolve the issue.
Task History ID - IjU3NjYwNTZjMDYzMjA0MzE1MjZhNTUzYzUxMzQ1MTYyNTQzNDBmMzQi_pc
image.png=========================================
Yes, you can connect your Facebook Page in Facebook Pages application.
https://youtu.be/J4L_bmkti34?si=TXGMKFUMObOil7pa&t=664
Arshil Ahmad
🌐 Pabbly.com
Just following up to check if you had a chance to update the route filter conditions as suggested and connect your Facebook Page in the Facebook Pages application. Please let us know if you're still facing any issues.
Arshil Ahmad
🌐 Pabbly.com
Christina Winter — Reply ·
Thank you so much for checking in! I was able to fix the problem with your help.
Arshil Ahmad
🌐 Pabbly.com
facebook
instagram
Christina Winter
Founder
Lead In Literacy | Leaders of Literacy
emailAddress
[email hidden]
website
www.leadinliteracy.com
Thank you for the update. We are glad we were able to help.
Arshil Ahmad
🌐 Pabbly.com
