Filter - Not set Issue
Status: Open · Asked by Fabsnebula on · 0 views
Your Workflow URL: https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTZkMDYzMDA0M2M1MjY4NTUzZDUxMzAi_pc
Task History ID: IjU3NjUwNTZkMDYzMDA0M2M1MjY4NTUzZDUxMzAi_pc
Hi, I use the filter to separate orders. It used to work. However, the past few orders did not go through because the filter says that it is NOT SET.
I am not sure what that means since I have already set up the filter with the proper options. And my orders do not have any other options.
Can you please assist? See screenshots
Hi @Fabsnebula,
Based on your task history, I can see that you are not receiving any data in the "Line Items 0 Parent Name" field from WooCommerce. Because of this, the Filter is receiving empty data, and it's showing up as "Not Set"
