Filter posts contain a word
Status: Closed · Asked by PablyAutoad on · 0 views
How can I set up a filter in Pabbly Connect to block posts containing specific words (e.g., "word1", "word2", "word3") from being forwarded from Telegram to my Facebook page, while allowing all other posts to go through?
Hello @PablyAutoad
Please try adding a filter as shown in the attached image to achieve your use case.
Hello, im using pabbly filter to block out those who do not purchase a specific product , and for those who purchase a specific product only , to be sent an automated email. so, i selected the label below like image below.
However, i noticed when someone purchase other product, my email automation went through this filter. Is it me, or am i missing some other step?
Thank you
Hello @esther012,
The issue arises because the same response has been mapped on both sides of the condition. As a result, the condition will always be met for every user. To ensure the filter functions correctly as per your requirement, please enter a static value or raw text in the value field instead.
Let me know if you need further clarification!
Hello when you mean "raw text" - meaning : like this ? the exact same word ? or otherwise the price value?
Im not sure in the "Label" column , am I writing it correctly.
Thanks for you response
Hello @esther012,
Yes, you entered the required value correctly please test it in real-time. If you face any further issues please let us know.
