Flodesk Segment not found
Status: Closed · Asked by Kirti on · 0 views
Kirti — Question ·
Hi there,
I'm trying to add new leads from FB leads to a specific flodesk segment.
I've set up the FB trigger and two Flodesk actions:
1. Create/Update Subscriber
2. Add Existing Subscriber to Segment
But in the second step I can't seem to find the segment that I want to add them to. It's not showing up in the dropdown, and when I choose "map" and add the segment ID, it results in an error.
Can someone please assist me?
Hi @Kirti,
You are supposed to map the Segment ID within the square brackets and double quotes. We have made the change on your behalf, which seems to have resolved the issue.
Kirti — Reply ·
Hi Arshil, Thank you so much!
