Flodesk Segment not found
Kirti
Hi there,
I'm trying to add new leads from FB leads to a specific flodesk segment.
I've set up the FB trigger and two Flodesk actions:
1. Create/Update Subscriber
2. Add Existing Subscriber to Segment
But in the second step I can't seem to find the segment that I want to add them to. It's not showing up in the dropdown, and when I choose "map" and add the segment ID, it results in an error.
Can someone please assist me?
ArshilAhmad
Moderator
Hi @Kirti,
You are supposed to map the Segment ID within the square brackets and double quotes. We have made the change on your behalf, which seems to have resolved the issue.
