Flodesk Trigger Problem
Status: Closed · Asked by Tasha on · 0 views
tasha.kaleidoscope — Question ·
I'm trying to connect Flodesk to Klavyio. Is there a way to trigger a Pabbly workflow when someone is added to a SPECIFIC segment in Flodesk? If so, could someone explain how to do it? I'm not able to select the specific Flodesk segment a subscriber is added to, which is possible in Zapier (see screenshot). I need the trigger to be based on someone being added to a specific segment. The only option I see would trigger when a subscriber is added to ANY segment, which is not helpful.
Hi @tasha.kaleidoscope,
You can add a Filter as the second step of your workflow and specify the Segment ID for which you want to execute the next step (Klavyio)
tasha.kaleidoscope — Reply ·
Thank you for the response. I saw that, but will it only be filtered by the label number selected? Because with 15+ Flodesk segments, there's a lot of label numbers.... (see screenshot).
Please consider making the changes to your Filter as suggested below.
Next, perform two test submissions:
  1. Add a dummy subscriber to the segment where you want the Klavyio step to execute.
  2. Add a dummy subscriber to the segment where you don't want the Klavyio step to execute.
Make sure to enable your workflow before making the test submissions.
