Flow disappear (solved)
Status: Closed · Asked by AlCukovic on · 0 views
Hi, I previously made a workflow. I worked on it for several days, but now it has disappeared. Do you think there is anyway to retrieve it ?
Hey @AlCukovic
Perhaps, you might have deleted the workflow or changed the name of the workflow.
You can manually search the workflow in your Pabbly account.
Actually it seems that my account was deleted. I logged in via same google account but everything was rebooted. I didn't pay the subscription yet but was planning to do it when I'm sure the flow is working
Sorry, my mistake, I logged with wrong google account...
