Flow failed again
Status: Closed · Asked by John Brocas (Jock) on · 0 views
My flow failed again and i did have the proper data.
[TABLE]
[TR]
[TD][JUSTIFY]Hello J Brocas,
This email is to notify you that for the workflow "PDN sc TO REDDIT" , a recent task was not executed due to following error - [/JUSTIFY]
Task History ID: IjU3NjcwNTY4MDYzNzA0MzI1MjZhNTUzMjUxMzU1MTZiNTQzOCI_3D_pc
Step Name: Reddit > Submit a Link Post
Connection Name: Reddit #afterlife
Task Error Detail:
"status": "error",
"message": "Required field Title, URL missing.
Yet the url was there[/TD]
[/TR]
[/TABLE]
Hey @Jock
As we can see from your shared task history log, it looks like you didn't get the published story data in your trigger response and because of that the action step didn't get the required field.
So, as a solution, we have set a filter condition in your workflow which will only work when the required are appearing from your Story Chiefs' account.
