Flow not working
Status: Open · Asked by ankit.s on · 0 views
ankit.s — Question ·
team mine is not fetching the last update.
my last update is ID14th in row 15th, but Pabbly always fetch 2nd last .
Due to which My flow is not triggering. Pls help
ankit.s — Reply ·
Team, I have created a flow & tested it with "save & send test request" In this case it always work in test but in reality its not working , I think the trigger is also not hitting as the flow is here.
When a new row will be added by form to excel , it will trigger the event & sent whatsapp msg. But its not triggering at all, its updating 2nd last & may be because of this the trigger is not hitting . I am not sure whats the issue, pls help.
Hello @ankit.s,
We are quite not clear about your concern please elaborate a bit more so we can better understand the issue. Also, please share the workflow URL where you're facing this issue.
