Flowlu connection does not work
Status: Closed · Asked by nocker on · 0 views
nocker — Question ·
Can you fix the problems with flowlu? There must be a mistake in the API settings...
my question to flowlu:
Hello, the import with pabbly connect does not work correct. I get the most of the time the message "Request rate per second exceeded".
Whats the best tool for connect flowlu with external data?
Thanks for help
Thomas
answer form flowlu:
Hello Thomas! Right now there is an issue with Pabbly regarding their integration with our API, so you can give Integrately, Make.com or KonnectzIT a try as well.
I have test with make.com too and the same problem...
Himesh Soni — Reply ·
Hello @nocker , This is API issue from flowlu.
You need to put Delay for 2-3 seconds after calling an API.
Automation Freelancer
Email - [EMAIL][email hidden][/EMAIL]
Hey @nocker
The error message "Request rate per second exceeded" indicates that you have hit the API rate limit set by Flowlu. Unfortunately, this limit is controlled by Flowlu team, and we do not have the capability to adjust it from our end.
We recommend contacting Flowlu's support team to discuss the possibility of increasing your API rate limit. This should help resolve the issue you're experiencing
As a workaround, you can consider doing what suggested by Himesh -
