Flowlu CRM Pipeline Automation from Typeform
Status: Closed · Asked by Dean_Chamberlain on · 0 views
Dean_Chamberlain — Question ·
I'm trying to get it to autopopulate the cost of the deal. The deals are consistently 1500 pound sterling but I feel I'm getting a few errors here on this workflow.
https://connect.pabbly.com/workflow/mapping/IjE4Mjg4MCI_3D
1. Won't just populate 1500 each deal where it says Budget which I'd like it to do (despite the fact I'm not pulling that data from typeform, just want it to automatically when it creates a deal to do that.
2. How to I get the relevant fields aligned. I want the name of the customer at the top as well where it's highlighted [Short_text]
Any help would be greatly appreciated.
Is this more of a flowlu issue or am i mixing something up inside my workflow here?
Dean_Chamberlain — Reply ·
I shared the workflow above for the automation in Pabbly you mean?
Hey @Dean_Chamberlain
We looked into your workflow and it seems like the budget field is directly coming from your Typeform and the budget which you are trying to pass on the field is different. Kindly type the budget amount manually/map if you are already getting it from the trigger response.
Further, from Typeform, the questions and their respective answers come in the last fields of the trigger response.
The fields which you have mapped in the Opportunity Name field are the field type. Kindly map the Form Response Answers from the trigger response to the respective fields of the Flowlu action step.
Please update your workflow as suggested and let us know how it works.
Amazing, you guys are perfect, that's fixed that.
