fluent form to pabbly connect data issue
Status: Open · Asked by Anas Zubair on · 0 views
hi i am using fluent form to pabbly connect. issue is coming in my one of field. documents are submitted in this field but pabbly is not fetching it. workflow url https://connect.pabbly.com/workflow/mapping/IjU3NjcwNTZjMDYzNjA0M2Q1MjY0NTUzMTUxMzIi_pc
getting this issue on my another account where i got lifetime subscription but no option of questions.
email
[email hidden]
Hi @Anas Zubair,
Please check the Passport Pic field and see if it provides the attachments you require.
Arshil Ahmad
?Rate your support
Hi that's a different field I need pass page pic data you can see in your screenshot
Hi @Anas Zubair,
Thanks for reaching out to us.
Upon checking, we noticed that you are using a webhook-based trigger. In this case, it appears that the information being sent from Fluent Forms does not include the specific field you are trying to capture.
We recommend checking this with the Fluent Forms team so they can review their webhook logs and confirm whether the required field is actually being sent in the webhook response.
Alternatively, you may use any third-party webhook provider and add it to the same form in Fluent Forms to verify the behavior. This will help confirm whether the specific field that is not being captured in Pabbly Connect is present in the webhook payload.
For testing, you can use webhook.site. Here is a tutorial that explains how to use it:
youtube.com/watch v=V0eih93WSj8
Please let us know the outcome so we can assist you further.
