Formaloo and Agiled.App
Status: Closed · Asked by Anupam on · 0 views
Hello Pabbly Team,
Looks like both formaloo and agiled.app are in pabbly connect. However one very important step is missing.
I want estimate to be sent from agiled.app whenever a form is filled in formaloo.
But in pabbly connect (for the agiled.app) , there is no option to select "Send Estimate". There is only option to delete the estimate.
When I reached out to Agiled.app team, they say that they already have API endpoint for creating estimates and this needs to be done from Pabbly Connect team.
Can you please help me achieve this.
Thank you
Anupam
Hey @Anupam
You can post the request to add the desired action event in the Agiled on the platform here - https://pabbly.hellonext.co/
Our integration team will look into it and include the action accordingly.
I just now posted request there. https://pabbly.hellonext.co/p/agiled-54a3750c-73ca-4882-bee8-c504891765ca
How long it may take to implement? It is kind of urgent.
Hey @Anupam
Implementing an action event requires multiple testing and constant monitoring of the integration which might take a little bit of time, so it is not possible to give you an ETA on any updation /creation of an integration.
Though we will try our best to provide the desired action event and we will notify you once our tech completes the integration as soon as possible.
I hope you would understand!!
Hey @Anupam
We check the upon your request for the "Agiled: Create Estimate" action step and the action event is not responding to the request on any of the platforms.
So as of now, it seems like the action step is not responding correctly from their server end in the current integration of Agiled.
Though we have contacted their support team for the same and would also request you to contact them as their action step is not responding correctly.
Hey @Anupam
We have added the desired action event of Agile in the current integration, kindly check this out and let us know if that works for you.
Only problem in this approach is how do we give Client User ID? So for each client new workflow is to be created? Cant we fill the client details in the form and estimate is automatically sent to the client?
Hey @Anupam
We looked into the API documentation of Agiled and we couldn't find anyway to get the Client User ID. So, we would request you to contact their support team on how you can get the Client User ID.
I think the "Client User ID" is email ID. Let me check with that.
