FreeAgent - Create Project
Status: Closed · Asked by Jo de Serrano on · 0 views
I am setting up a connection from my CRM to FreeAgent via Pabbly Connect and the Create Project step asks for a billing period, only billing period doesn't exist in FreeAgent and so it is impossible to complete the step. It is a required field, so it can't be left blank. I have attached screenshots of a project setup in FreeAgent.
Hello @jods1972,
Yes, those fields are required. You can fill in the Billing Period and Hours per Day fields as explained in the help text.
Essentially, it depends on the specific project — how many days you’ll be working and how many hours you’ll invest each day. For example, if the project will take 7 days and you’ll work 2 hours per day, then set Billing Period = 7 and Hours per Day = 2.
Please fill in the fields accordingly and let us know how it goes.
Hi. I have it set at 7 hours per day and tried all kinds of numbers in the billing period box, 1, 0, 30, 7 and all comes up as an error. Billing period is not a field in FreeAgent so this information will not be transferred. This isn't my user error, this is a setup error, so I think it needs amending by Pabbly Connect.
Hello @jods1972,
You do not need to enter any number in the Billing period. You can either add a text, day, or hour. Try testing with it and let us know how it goes.
Hi
OK - so it works when I put in hour, but not Hour, nor month or Month.
Thanks for the help
Jo
and I hope you have a lovely day :)
Hello @jods1972,
Glad it worked.
As your issue has been resolved, we’d appreciate it if you could share quick feedback on the support received:
Thank you for your time.
PS: We are closing this thread as the issue is resolved. Please feel free to reach out to us if you face any issues in the future.
