Full Project ID Not Extracted
Status: Closed · Asked by David Ho on · 0 views
david — Question ·
There alot more project ID on my actual workspace but it's not listed here. Pabbly is unable to capture the full Project ID list from the application named Blue. Why is that? How can I resolve it?
david — Reply ·
PabblyMember4 — Reply ·
Hey @david
We have increased the limit to show the 100 project ids in the Blue app. Kindly check and let me know if you have any questions or comments.
david — Reply ·
@Kunal Valuskar May I know why are there limitations? What are the other limitations for Blue that are in place on Pabbly?
Hey @david
We have put the limitation to restrict the unnecessary flow of data which is causing extra load on the servers. As of now, there is no limitation on the Blue app. Please let me know if you have any questions or comments.
Hey @david
Could you please let me know if out of 5 only 3 tags are coming from the trigger then you want all 3 tags or all the 5 tags in the workflow? Please confirm so that we will check with the team if this scenario is possible or not.
david — Reply ·
Hi Kunal,
We want to know how we can get any chosen tags to come from the trigger (depending on whether or not the text field of this tag is empty or not). If all 5 tags were chosen, then we want all 5 to come through, if 2 or 3 were chosen, then we want the 2 or the 3 to come through. The number of the tags that come through depends on which ones the user chose while filling the form (in the backend, which text fields are not empty)
Hey @david
To pass the individual tag combination based on the specific keyword from the trigger response, use the Router action step for each tag combination you want to process further.
