G-Sheet to Pabbly Automation Not Working
Status: Open · Asked by Wellness Vibe on · 0 views
Hi Pabbly Team,
We are facing an issue with our Pabbly automation integrated with Google Sheets.
The workflow is supposed to capture any update made in a specific row, however Pabbly is not capturing the update event when the row data is edited/updated. Because of this, the automation is not triggering as expected.
Request you to please check and help us resolve this issue at the earliest.
Details:
- Integration: Pabbly + Google Sheets
- Expected behavior: Trigger should capture updates on a specific row
- Current issue: Updates are not being captured / trigger not firing
Registered ID: [EMAIL][email hidden][/EMAIL]
Please let me know if you need any additional details from our side.
Hi @Wellness Vibe,
Could you please explain how you are adding data to your spreadsheet? Are you adding the data manually, or through a third-party application or API?
It appears that you have disabled your workflow. Please enable the workflow again and then add data to your Google Sheets spreadsheet.
Arshil Ahmad
?Rate your support
