Gemini Not Allowing to add "Method"
Status: Closed · Asked by exponexa on · 0 views
exponexa — Question ·
When using the gemini feature to generate content it will not allow you to select the "method" type. This is in the new workflow builder but seems to be working fine in the old builder.
exponexa — Reply ·
It appears this is also happening with the google sheets within the new workflow builder.
Himesh Soni — Reply ·
Hi first try with incognito mode and if it still not works try to rebuild workflow with V1 as V2 is in still beta mode. If you are still not able to solve this on your own feel free to DM me and we can do a free zoom call. FYI I'm not from Pabbly Connect team, just a freelancer who helps other Pabbly users.
Automation Freelancer
Email - [email hidden]
