Generate Conteny using OpenAI
Status: Closed · Asked by sachinites on · 0 views
I recvdd the notification that openAI-Generate content Step in my workflow is deprecated, and I have to delete the step and re-create it again in workflow. The step was to generate content using Open-AI.
Now, When I am re-creating this step again, which model of chat-gpt is to be selected.
Pasting the options here :
which option to be selected for generating content. I tried chatGPT and chatGPT ( Advanced ) , and after that i selected chatgpt--***-instruct , but it did not work in generating content. Pls help.
You can try using the advanced version of the Chat GPT for your concern.
This is the response i recvd when i click "Save and Send Test Request" Button.
Configuration :
It says in Message field I have to provide the Json code. how can i configure a json code here which picks up inputs from prev steps ( Row0 and Row1 )
my workflow has stopped because of this. Pls give correct resolution. Which openAI model to use for content generation if the previous one has been deprecated. I tried all which are listed in drop down menu, but none of them meet the requirement.
Hey @sachinites
Please carefully go through the help text in the Message field, and then respond to the prompt accordingly. The JSON error is cropping up because you're directly passing content without following the specified guidelines.
Additionally, you have the option to utilize the "ChatGPT" action step from OpenAI at your convenience.
