Glitch in sending HTML Body
Status: Closed · Asked by Arie Moller on · 0 views
Arie — Question ·
So I have a autoreply in Google mail that takes the original email and pastes the contacts of the HTML body after the welcome message. It works but for some reason there is a ton of gibberish after the copied HTML. I think it's from the original parse of the email. Attached is the screen grabs. All is great until number 3.
Hi @Arie,
Could you please make a short screen recording elaborating a bit more on this issue? Also, share the Workflow URL in which you have this concern.
The HTML body captured in the Email Parser response contains additional information. I suggest removing this part from the HTML body and mapping the remaining portion in the Gmail action step. This should help you resolve the issue.
